Why is it that "Modify Panel > Appearance" in the left navigation tab > Mesh Data > select Use Input, when I load a new cloth sbsar only one channel in one row?
It will happen in some special situation, for now you work around this issue by:
Drag the UI Layout after you select the Use Inputs option, it would be show Height , Normal , Color ID , WS Normal , AO.
