How to import iClone 3D Motions into Cartoon Animator 4?
Menu
Search
Reallusion Support
Download and Installation
To import iClone 3D Motions you will need Cartoon Animator 4 Pipeline version, and a G2 character in your scene.
For importing iClone 5 embedded 3D motions you will need to: -
1) First, apply a G2 Character in the stage. Please note that iClone motions are only supported by G2 characters.
2) At the Main Menu, select File > Import Animation.
3) Open and find the .iMotion file to import.
For iClone 6/7, to create a new motion you will need to export the motion file as a .rlMotion format: -
1) Load motion into a 3D character in iClone 6/7.
2) Open the Timeline and find the motion clip.
3) Use the Collect Clip track to select the motion range.
4) Right-click the mouse, to choose "Add Motion to Library".
5) In the drop-down file type choose “RL Motion Files”.
6) Then import the .rlMotion file into Cartoon Animator 4, by following the above step.
Also In This Category
On a scale of 1-5, please rate the helpfulness of this article
Not Helpful
Very Helpful
Optionally provide your comments to help us improve this article...
Thank you for your feedback!
Details
Last Modified: 4/26/2019 3:08:42 PM
Last Modified By: Reallusion Support
Type: FAQ
Article not rated yet.
Article has been viewed 740 times.
Options
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 8 queries. Compression Disabled.
