How to adjust my imported audio clips to the maximum supported length of the project?
The default length for each project is 1,800 frames and the maximum frame number can be set is 54,000 (15 minutes).
By the way, you need to adjust Time Settings if your imported audio clip is more than 1,800 frames (~1 minutes), or else your project will stop at the default setting.
