How to adjust my imported audio clips to the maximum supported length of the project?
Menu
Search
Reallusion Support
Software Usage
The default length for each project is 1,800 frames and the maximum frame number can be set is 54,000 (15 minutes).
By the way, you need to adjust Time Settings if your imported audio clip is more than 1,800 frames (~1 minutes), or else your project will stop at the default setting.
詳細
最終更新: 4/14/2016 3:14:13 AM
最終更新者: Reallusion Support
タイプ: FAQ
閲覧​回数: 3.6K
オプション​
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 7 queries. Compression Disabled.
