To import iClone 3D Motions you will need CrazyTalk Animator 3 Pipeline version, and a G2 character in your scene. For importing iClone 5 embedded 3D motions you will need to: - 1) First, apply a G2 Character in the stage. Please note that iClone motions are only supported by G2 characters. 2) At the Main Menu, select File > Import Animation. 3) Open and find the .iMotion file to import. For iClone 6/7, to create a new motion you will need to export the motion file as a .rlMotion format: - 1) Load motion into a 3D character in iClone 6/7. 2) Open the Timeline and find the motion clip. 3) Use the Collect Clip track to select the motion range. 4) Right-click the mouse, to choose "Add Motion to Library". 5) In the drop-down file type choose “RL Motion Files”. 6) Then import the .rlMotion file into CrazyTalk Animator 3, by following the above step.
