Renaming layers or subtool causes problems with the plugin.
Cause: ZBrush Face Tools relies on strict naming conventions to operate properly. Therefore, changing the names of layers or subtools can lead to unforeseen issues.
Known issues (auto rename):
- Serializing of names after executing GoZ.
- Name changes caused by crashes during auto save.
- Renaming the file when saving a subtool.
Solution: Don’t manually rename layers or subtools. If an item has been renamed, then you will need to export (create new) the CC character again to ZBrush.
