Renaming layers or subtool causes problems with the plugin.
Menu
Search
Reallusion Support
Cause: ZBrush Face Tools relies on strict naming conventions to operate properly. Therefore, changing the names of layers or subtools can lead to unforeseen issues.
Known issues (auto rename):
- Serializing of names after executing GoZ.
- Name changes caused by crashes during auto save.
- Renaming the file when saving a subtool.
Solution: Don’t manually rename layers or subtools. If an item has been renamed, then you will need to export (create new) the CC character again to ZBrush.
Also In This Category
Details
Last Modified: 10/12/2023 8:42:41 AM
Last Modified By: Reallusion Support
Type: FAQ
Article has been viewed 1.1K times.
Options
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 8 queries. Compression Disabled.
