How does Cartoon Animator 4 access the previous version DRM contents?
Menu
Search
Reallusion Support
Download and Installation
All CrazyTalk Animator contents are compatible with Cartoon Animator 4. There are two methods available and we recommend Method #1.
Method #1: -
The easiest way to bring in all your previous version CrazyTalk Animator content is to simply reinstall all your content packs (via Universal Installer) as this will directly add them into your Cartoon Animator 4 folders.
During content packs installation, simply check Cartoon Animator 4 for specified version.
Method #2: -
1) Manually copy all content from CrazyTalk Animator previous version to Cartoon Animator 4's corresponding location. Please DO NOT replace the files with the same name in order to avoid any version mismatch.
Folder reference: -
Windows
CTA1 Template folder: (Vista/Win7/Win8/Win10)
C:\Users\Public\Documents\Reallusion\Template\CrazyTalk Animator Template
CTA1 Template folder: (WinXP)
C:\Documents and Settings\All Users\Documents\Reallusion\Template\CrazyTalk Animator Template
CTA2 Template folder: (Vista/Win7/Win8/Win10)
C:\Users\Public\Documents\Reallusion\Template\CrazyTalk Animator 2 Template
CTA2 Template folder: (WinXP)
C:\Documents and Settings\All Users\Documents\Reallusion\Template\CrazyTalk Animator 2 Template
CTA3 Template folder: (Win7/Win8/Win10)
C:\Users\Public\Documents\Reallusion\Template\CrazyTalk Animator 3 Template
CTA4 Template folder: (Win7/Win8/Win10)
C:\Users\Public\Documents\Reallusion\Template\Cartoon Animator 4 Template
Mac
Users/Shared/Reallusion/Template/Cartoon Animator 4 Template
2) Since these digitally protected content were not installed using their original installers, nor downloaded from the BackStage, then they need to be re-verified for use in Cartoon Animator 4.
Please go to main menu, "Help" -> "Activate Entire Library", this will help you verify all your templates and custom content in a single go.
After clicking "Activate Entire Library", a confirmation dialog will pop up. Read the information carefully and click on "OK" to begin the verification process.
Please note that the verification requires an internet connection.
Also In This Category
Details
Last Modified: 6/9/2020 6:03:04 AM
Last Modified By: Reallusion Support
Type: FAQ
Article has been viewed 10K times.
Options
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 8 queries. Compression Disabled.
