I can't adjust existing keys after I apply Speed Change or Time Warp to the clip, or adjust the project fps.
Menu
Search
Reallusion Support
Apply filters to the animation clip can cause the keys within to displace toward fractional frames, make it difficult to adjust the keys when the frame selection is restricted to full-frame only. Use either method to below to solve this problem:
Option 1: After applying filters to the clip or adjusting the project fps, flatten the entire clip and resample the keyframes.
Option 2: Manually delete the unnecessary fractional keys for clip regions you would like to adjust.
Also In This Category
Details
Last Modified: 11/27/2024 3:23:32 AM
Last Modified By: Reallusion Support
Type: FAQ
Article has been viewed 3.9K times.
Options
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 11 queries. Compression Disabled.
