How does CrazyTalk Animator 2 access the CrazyTalk Animator 1 DRM contents?
Menu
Search
Reallusion Support
Download and Installation
All CrazyTalk Animator 1 contents are compatible with CrazyTalk Animator 2. 2 methods available and recommended method#1 to be used.
Method#1: -
The easiest way to bring in all your CrazyTalk Aminator 1 content is to simply reinstall all your content packs as this will directly add them into your CrazyTalk Animator 2 folders.
During content packs installation, just simply check CrazyTalk Animator 2 when prompt.
Method#2: -
1) Manually copy all contents from CrazyTalk Animator 1 to CrazyTalk Animator 2 correspondence location. Please DO NOT replace the files with the same name as this is to avoid any version mismatch.
Folder reference: -
CTA1 Template folder: (Vista/Win7/Win8/Win10)
C:\Users\Public\Documents\Reallusion\Template\CrazyTalk Animator Template
CTA1 Template folder: (WinXP)
C:\Documents and Settings\All Users\Documents\Reallusion\Template\CrazyTalk Animator Template
CTA2 Template folder: (Vista/Win7/Win8/Win10)
C:\Users\Public\Documents\Reallusion\Template\CrazyTalk Animator 2 Template
CTA2 Template folder : (WinXP)
C:\Documents and Settings\All Users\Documents\Reallusion\Template\CrazyTalk Animator 2 Template
2) Since these digitally protected contents were not installed using their original installers, or downloaded from BackStage, they need to be re-verified for use in CrazyTalk Animator 2.
Please go to main menu, "Help" -> "Content 1-Click Verification", this will help you verify all your templates and custom contents in a single go.
After clicking "Content 1-Click Verification", a confirmation dialog will pop up. Read the information carefully and click on "OK" to begin the verification process.
Please note that the verification requires an internet connection.
Also In This Category
Details
Last Modified: 11/9/2016 8:14:46 AM
Last Modified By: Reallusion Support
Type: FAQ
Article has been viewed 4.4K times.
Options
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 10 queries. Compression Disabled.
