Menu
Home
General
Purchase
Product
Search
Back
Reallusion FAQ
Traditional_Chinese
Japanese
German
Reallusion FAQ
Useful Tips
Home
General
Purchase
Product
Latest
Popular
Home
Product
FaceFilter (EOL)
FaceFiler 3 (EOL)
Software Usage
When applying an expression, the changes don’t' seem to be...
When applying an expression, the changes don’t' seem to be totally correct.
12/15/2017
Reallusion Support
Software Usage
A poorly or incorrectly fitted mask will not give the best results, so please check the following items while fitting:
(1) Ensure that the facial region selected with the bounding tool is straight, rotate if required.
(2) Ensure that each of the nodes on the facial mask is applied accurately.
You can also adjust the strength of different muscle effects to make more natural expression.
Also In This Category
Can I select both two kinds of expression?
Can I use the Undo function in Reshape to return to the status before Keep Result? If yes, how many times can I do that?
In the Reshape section, is it possible to apply my facial shape modifications to all of the subjects in a photo?
What should I do if my face is blurred after using the Skin Smoothing function?
Why do I not see any changes when I apply any skin refinement?
How can I add a custom color to my facial and body skin?
Why can't I remove all the red eyes in my image via "red eye reduction" function?
Why does the size of the image not match the original size in Face Filter 3?
Why does some in-program text display abnormal in Face Filter 3 ?
Details
Last Modified:
12/15/2017 7:38:47 AM
Last Modified By:
Reallusion Support
Type:
FAQ
Article has been viewed 1.6K times.
Options
Print Article
Export As PDF
Customer Support Software
By InstantKB 2015-2
Execution: 0.000.
11 queries.
Compression Disabled.
