Why does the color of the clothes change when brought into FashionGen?
Menu
Search
Reallusion Support
FashionGen
Please check whether the clothing material in Character Creator has had its color adjusted. FashionGen cannot read these color adjustments. To avoid color changes, it is recommended that you either reset the color tint to white before editing in FashionGen or replace the color directly within FashionGen. When the results are sent back from FashionGen to Character Creator, the original color will be overwritten.
This issue typically does not affect Reallusion-created content, as it is published with the tint set to white to ensure full compatibility with FashionGen.
Also In This Category
Details
Last Modified: 12/22/2025 6:10:30 AM
Last Modified By: Reallusion Support
Type: FAQ
Article has been viewed 871 times.
Options
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 8 queries. Compression Disabled.
