Why when I uninstall a product through the Control Panel > Uninstall Program, is the product still in the Reallusion Hub?
Menu
Search
Reallusion Support
The Reallusion Hub does not do real-time detection with each uninstallation process, but it will update after you manually remove your program. You can also click "Refresh" to update the product status. If you still see it in the "Not Installed" area, then it means that we keep your product in the backend.
Also In This Category
Details
Last Modified: 12/26/2017 5:52:19 AM
Last Modified By: Reallusion Support
Type: FAQ
Article has been viewed 2.6K times.
Options
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 11 queries. Compression Disabled.
