How to solve incorrect facial expressions when using face puppet with Little Mates content?
Menu
Search
Reallusion Support
Software Specification
If you wants to change the default facial sprites in order to record face puppet animations, then you need to follow the below steps to modify their characters. For example in the below figure, you wants to use "glasses-2" to record an expression with the face puppet.
1) Import a Little Mates character into CrazyTalk Animator 3, then go to the Composer Mode.
2) Open the Sprite Editor, and remove the Normal (nose) and all the others sprites. Then setup the "glasses-2" as a default sprite.
3) Go to the Stage and open the Face Puppet panel. The Face Puppet will now work.
Also In This Category
Details
Last Modified: 9/4/2017 9:39:01 AM
Last Modified By: Reallusion Support
Type: FAQ
Article has been viewed 4.2K times.
Options
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 12 queries. Compression Disabled.
