My motion has a slight turn to it. When I set it up as an interruptible motion and trigger it again, the motion trajectory keeps on veering. Should I remove the slight turn in the motion?
Menu
Search
Reallusion Support
v8.4
You can open the 'Behavior' list and right click on the problematic Perform motion and select 'Align Perform Direction'. This will force the motion to continue on it's initial trajectory. However, if the Perform motion suddenly changed direction midway through (like doing a backflip), then the orientation needs to be fixed on the root motion.
Also In This Category
Details
Last Modified: 11/24/2023 1:30:37 AM
Last Modified By: Reallusion Support
Type: FAQ
Article has been viewed 1.1K times.
Options
Customer Support Software By InstantKB 2015-2
Execution: 0.000. 10 queries. Compression Disabled.
