Menu
Home
General
Purchase
Product
Search
Back
Reallusion FAQ
Traditional_Chinese
Japanese
German
Reallusion FAQ
Useful Tips
Home
General
Purchase
Product
Latest
Popular
Home
Product
iClone 8
v8.4
The character I'm controlling with waypoints gets stuck...
The character I'm controlling with waypoints gets stuck in-place when it tries to avoid an obstacle.
11/24/2023
Reallusion Support
v8.4
Enable 'MD Control > General Settings > Reroute Stuck Agent' to free your stuck character.
Also In This Category
My heavy 3D scene (lots of materials, or high polycounts) has a low fps which is causing the MD characters to perform poorly. What can I do to solve this issue?
Triggered perform motions that were just added into iMD do not blend smoothly with other motions.
Motion pool motions are not being applied when Actor Groups are scattered via the 'Crowd Gen' interface.
The constraint settings that I've configured for actor groups do not seem to take effect.
If the connection weight is adjusted to 1 for a specific control point while the connecting walkway is set to zero, the character will turn back around.
How can I address character issues stemming from disruptions in its path or difficulties navigating slopes caused by a broken NavMesh that protrudes through the floor, as indicated by red borders?
How to keep the character in place, instead of pacing about on a narrow NavMesh.
My motion has a slight turn to it. When I set it up as an interruptible motion and trigger it again, the motion trajectory keeps on veering. Should I remove the slight turn in the motion?
Character may overstep path and walkway regions.
Details
Last Modified:
11/24/2023 1:35:19 AM
Last Modified By:
Reallusion Support
Type:
FAQ
Article has been viewed 1.1K times.
Options
Print Article
Export As PDF
Customer Support Software
By InstantKB 2015-2
Execution: 0.000.
9 queries.
Compression Disabled.
